Evap System
Just found out I have a problem with my evap system (97 Grand Prix GTP). My SES light comes on intermittently. Not sure what the number of the code is, but my mechanic said it was because the vacuum was too strong (not a leak). He said could be from a kink or clogged hose. Any ideas what this could be? Are the hoses and canister easily accessible for me to check?
Re: Evap System
Here are the common evaporative emissions system DTCs at the link below. To help we need the DTC (code) so post it if you have it.
Click here The vent solenoid and evaporative cannister are located at the rear driver's side of the car. You have to look up from underneath in the proximity of the rear fenderwell area.
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 02-10-2008 at 08:26 AM. |
Re: Evap System
Thanks, Bob. I was in a bit of a hurry and forgot to ask my mechanic for the number of the code.
I will try to find out on Monday.
Re: Evap System
The code was on my receipt. It's 1441B. I found one page that lists this code as "P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge."
Re: Evap System
For whatever it is worth, I had a similar problem with a different code. My code was 441. Here is the link. Apparently I have a different evap system than the later 97 models. Yours may or may not be like mine.
http://www.automotiveforums.com/vbul...ighlight=purge
1997 Grand Prix SE, 3.8 (L36), 4T60-E (auto) M13 2002 Grand AM SE1, 3.4 (LA1), 4T45-E (auto) MN5 2003 Silverado LS, 5.3 (LM7), 4L60-E (auto) M30 1988 Ford Bronco EB 5.0 (AOD) manual BW1356 & hubs |
Re: Evap System
Good point jem270 so other members don't get confused with the slight differences in the evaporative emission systems between the years. The system you have should be applicable to all '97 to '98 GTP, GT and SE (3800). It changed to where the tank pressure switch was moved to the fuel pump pod in the 1999 model year.
What I have for extended odb-ii DTC P1441 is a purge solenoid stuck open. So that component is a possibility. The switch vacuum state should toggle low (closed) if there is no vacuum applied to the system.
Re: Evap System
Thanks for the link, jem270. The pictures are great and I've got a better grasp on the system now.
Re: Evap System
Re: Evap System
Thanks, Bob. Looks like the solenoid is a pretty cheap part, so I'll probably just replace it.
Re: Evap System
Can i bypass the evap system? If so how?
Re: Evap System
No.....
