| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
04 cavalier driver side dim headlight
what would cause the driver side headlight to be in dim in drl mode, low beam, and high beam, tryed replacing bulb didn't do anything, also fog lights won't turn on and if you switch to high beam the high beam indicator stays on in the dash sometimes the service lights come on also, it also appears the front running lights aren't working either
Re: 04 cavalier driver side dim headlight
I'm having a similar problem with the running lights and my left front headlight out. Please let me know once you've figured anything out.
Thanks!!! |
I would start looking at a bad ground issue. there could be two different problems here at the same time.
are the fog lights hard wired right into the vehical or added later and do they have there own switch. |
they are the factory headlights, I've been told its probably the switch in the column, I'm taking it in later this week to get it checked out
