Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 02-09-2008, 05:39 PM
mlchris mlchris is offline
Sand blasters
Has any one out ther use a sanblaster with a vacuam assist. I live in Idaho and it is cold and wet for several months. Just need to kow if this vacuam assist is adequate if using indoors. Any ideas.
Old 02-09-2008, 06:15 PM
j cAT j cAT is offline
Re: Sand blasters
sand blasting indoors will require air pressure breathing mask/resperator. as you know silica dust will be created and your surface contaminates like chromium/cadmium etc will be injested by you and the structure. plastic bead is safer but still need protection.
Old 02-09-2008, 08:20 PM
denisond3 denisond3 is offline
Re: Sand blasters
Are you talking about doing sandblasting in a cabinet? In that case I regard the vacuum assist as being a neat feature - but expensive enough that I did without: Though I was just a hobbyist, wasnt earning money at it. And I never wanted to use any silica sand abrasive in a cabinet. For the big rusty stuff I waited till it was decent weather outdoors for blasting with '#2 quartzite' from a little 35 lb tank.
If you are talking about sandblasting within a building but not using a cabinet - I never considered that worth the trouble, just based on the cleanup and the repairs to the building structure, let alone the damage to my lungs.
Old 02-10-2008, 10:39 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Sand blasters
Where do you guys get your media? What is the price difference between sand and plastic?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-11-2008, 09:57 AM
Re: Sand blasters
Try a search at google.com, using the words " +sandblasting +media ". The plus signs mean that both of the words need to be in the sites, or they wont appear in the results. Hopefully the manufacturers/distributors will have local outlets you can deal with.
You will soon be an expert the difference between the cost of the many alternatives. The 'sand' was the only stuff that I could afford to use outside. For most other stuff the industry probably uses some kind of cabinet for capture/re-use. But most of my blasting was for big driveline items anyway; wheels, axles, brake drums, frames, etc.
Even though I lived in the Washington/Baltimore metro area at the time, I still had to drive quite a distance to get my supplies. From a place that did beadblasting I also got some used steel shot (just for the work of hauling it away), which worked well for the small amount of work I did using a cabinet.
Old 02-11-2008, 06:46 PM
kahjdh's Avatar
Re: Sand blasters
I have a brush gaurd with rust so I wanted to repaint it. Do I need special nozzles for different media?
Current Cars:
Past Cars:
