Old 02-09-2008, 03:50 PM
Atrus96 Atrus96 is offline
Would this work?
ok if you had a single voice coil sub that was 4 ohms could you add a 4ohm resister inline in the positive power cable from the amp to present the amp with a 2 ohm load to give the sub more power from the amp?
Old 02-09-2008, 03:55 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Would this work?
no.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 02-09-2008, 03:57 PM
ok just out of couriousity. why?
Old 02-09-2008, 04:56 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
well, you actually can ..... and it will lower the load by 1/2. Problem is, the speaker and resistor will each dissipate 1/2 of the total power. So if you had a 100 watt amp (at 4 ohms) connected to speaker and a 4 ohm resistor - the amp would put out 200 watts. The speaker would receive 100 watts and the resistor would receive 100 watts, so you would be right back where you started from, only now you're amp is drawing twice as much power from your electrical system. There actually is a way to do what you want to do, problem is it would be cheaper to just buy a 200 watt amp.
