Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-09-2008, 02:14 PM
Cokeezy Cokeezy is offline
Sitting 1 Year
I hope I an doing this right first time on here. i just need a little advice. I was given a 91 Caprice that has been sitting for a year. Good car. Any better ideas on how to get it started.
Old 02-09-2008, 02:42 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Sitting 1 Year
I'd change the oil and filter, check all the fluids, add some fresh gas to the tank, check the tire pressures, see if the battery is fully charged for starters. That is what I have done to my vehicles that have been idle for a year or so. Most of these modern fuel injected vehicles will start after sitting a year which is good compared to the old carburetored types that had trouble if the gas was stale. I still add some fresh fuel to mix with the old stuff in the tank for better chances of starting.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 02-09-2008, 03:53 PM
mike561 mike561 is offline
Re: Sitting 1 Year
right on, def change the oil as soon as you can, you dont know how long its been sitting in there.
2006 Chevy Cobalt LS
Old 02-09-2008, 06:11 PM
Re: Sitting 1 Year
Also might consider changing the transmission filter and fluid after you get the vehicle started and running.
Old 02-09-2008, 06:43 PM
j cAT j cAT is offline
Re: Sitting 1 Year
this is simular to prep boat engine for use in spring in addition to other suggestions, before starting/cranking it is a good idea to remove plugs and add 1oz of marvel mystry oil into the cylinders. let it sit for a day and then go for it. it is possible the rings will be stuck rusted and this will hopefully prevent cracking a ring.....
