Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-09-2008, 03:00 PM
Suegrw2 Suegrw2 is offline
Unhappy 98 Ford Crown Vic
When I turn my ignition on the lights come on but I cant get the motor to turn over. Ive replaced the relay and still doesnt start. I can start it by hotwiring the box on the column. Any suggestions?
Old 02-19-2008, 09:57 AM
Stale Trooper's Avatar
Stale Trooper Stale Trooper is offline
Re: 98 Ford Crown Vic
First 2 things that come to mind are the Ignition switch on the column, and the 'box' (the actual switch part) on the lower column. You may just need to adjust this, to get the car to start. Probably move it a tiny bit closer to the top of the column, also, check the connecting rod between these parts to be sure it isn't bent. Hope this helps!
Stale Trooper
'05 CVPI
(My '99 got wiped out with 238,513 miles on the clock, stupid woman driver)
It's White, with a black grille, a spotlight, and the butt is black. Need a picture? Thought not
