Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-09-2008, 09:35 AM
bluebird1955 bluebird1955 is offline
Question Which fluids to use
Hello to all of you, I wonder if you couyld give me some advice.
I bought a 1998 Jeep Grand Cherokee Orvis with 61000 miles on the clock, and after driving it for 2000 miles it is time for a service. I have read numerous articles about the fluids to use in the transfer box, the axles and the transmission. There is talk about Dexron 2 and 3, mopar atf4 etc. Which fluid should I use to best protect my vehicles engine/transmission/drive train etc?
Are there any additives that will make the whole lot quieter and more efficient?
Any help would be much appreciated.
Old 02-10-2008, 08:31 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Which fluids to use
I recommend flushing your Transmission and switching to ATF +4. You should never use dexron (of any grade) in your transmission. but once you switch to ATF+4 make sure you stick with the ATF+4.
As for the transfer case, you can use dexron in this and maybe some LUCAS if you want. Engine oil I use Synthetic MOBILE1
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 02-11-2008, 06:09 AM
Hi dksob81, which Dexron should I use, 2 or 3? What is the difference?
When I flush the transmission, how do I flush the cooler and pipes?
Thanks
Old 02-12-2008, 07:59 AM
You can use either Dex 2or 3 for the Transfer Case.
As for flushing the transmission, take it to a quick lube, they will be able to flush it for you but I would bring your own Transmission Fluid, Akit if quick lubes use a multi-vehicle type tranny fluid and you might do more harm then good. Chrysler transmission are very tempermental about the type of fluid and you can easily burn it up using the wrong fluid. It is recommended to use ATF+3 but I like to use the ATF+4 which from what I was told is MOPAR synthetic version of the ATF+3. But the ATF+4 is a lil pricey around $5-$6 a quart. and you will need about 12 quarts +/-
Old 02-13-2008, 09:09 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Consider that a flush with a 10 year old vehicle may loosen some dirt deposits and cause a problem. You may want to consider instead just dropping the pan and changing what's in there (then again in 20K miles)
Definitely don't use Dexron in the transmission, stick with ATF+4, which can also be used in the transfer case.
For the axles, I think 80w90 is recommended. If you have a limited slip in the rear, you will probably need a friction modifier.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-18-2008, 01:58 PM
Hi,
My transfer case has a metal label attached that says New Process, what does that mean?
Old 02-18-2008, 04:46 PM
New Process is the name of the company that manufactures your transfer case. New Process and NEW VENTURE are the same company just changed the name a couple times.
Old 02-18-2008, 04:50 PM
Thank you all for your help. I now feel able to get the oils changed.
