Old 02-08-2008, 10:58 PM
Morpheus_P Morpheus_P is offline
Send a message via MSN to Morpheus_P Send a message via Yahoo to Morpheus_P
Smile A/C Flush-Recharge
Just wondering what I should know before I take my "02" 3.5 into the shop for a full flush, lube and refill of the entire A/C system... THX Again!
Old 02-09-2008, 07:48 AM
busboy4 busboy4 is offline
Re: A/C Flush-Recharge
Hi
did you have/do any A/C work? I know that a flush is often called for after a compressor failure to ensure no foreign matter is stuck in the freon lines/fittings. But Flushing the system to my knowledge is not a routine process. If you have leaked all the freon, certainly finding and repairing a leak prior to a proper refill is important.
Old 02-09-2008, 09:01 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Yeah unless there was some work performed or you had a leak that is not a routine procedure. The refrigerant should last the life of the vehicle unless there is a problem of some kind. Occasionally you can benefit from adding some to the system, but thats generally because of a small leak.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 02-09-2008, 09:12 AM
Cool Re: A/C Flush-Recharge
Well, it appears when I check my R134 level with the gauge I am in the red (Danger) It appears I may have a blockage in one of my lines because my compressor is kicking on. BTW I am the original owner of the "02" and I never serviced the A/C. So...
