Old 02-08-2008, 10:56 PM
91silverado 91silverado is offline
electrical problems
my truck was running but it shut off for no reason, i went to start it and it sounded like it was trying to turn over but it sounded like the battery was dead. i let it crank for a few seconds, and smoke started comming up towards the back of the motor. any idea what this could be?
Old 02-09-2008, 04:09 AM
16th hippy 16th hippy is offline
Re: electrical problems
year, make, model, engine size? exactly what area of the engine was producing smoke? how long did you crank it for? need more info from you to try and help. i could say that the fuel pump died, and as a result of you cranking it so long, you fried the starter. but i would rather have the info so i am not shooting into the wind. I hate throwing parts at something...lol. get info ASAP and i will try to answer in same fashion.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 02-09-2008, 09:16 AM
its a 91 c1500 with the 305, the smoke was cumming from behind the aircleaner on the motor, back towards the wiper motor. the smoke was just a little bit but it smelled electrical
Old 02-09-2008, 09:55 AM
j cAT j cAT is offline
this smells like a fuseable link that corroded or starter connections that need wire repair . in any case it appears to be electical wire to starter or solenoid
Old 02-09-2008, 10:08 AM
thanks alot guys, im gonna go out right now and check out the wires on the starter. hope this is the problem... again thanks
