Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 02-08-2008, 08:13 PM
Totalfog Totalfog is offline
Power Steering fluid.....
I have a 2002 Passat Wagon, 4Motion. It needs power steering fluid. I THINK I've identified the proper receptacle in the engine --- in the right front of the engine, it has a green cap on it. But I don't want to find out the hard way that I was wrong. I would appreciate it if someone could either confirm this or correct me.
Thanks very much.
Old 02-12-2008, 11:08 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Power Steering fluid.....
yes, its the resivour right behind the driver side headlamp with the green cap
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-10-2008, 09:55 PM
jackcolorado jackcolorado is offline
Now good luck finding the correct fluid. I finally found it at a Napa.
Old 08-10-2008, 10:11 PM
VDUBMAN
the correct fluid is only found at vw. It is a mineral based synthetic power steering fluid. You may be able to find it at a aftermarket european shop (pentosyn fluid) but napa does not sell it where I am.
Old 08-10-2008, 10:21 PM
Ya, that is what I got. It isn't cheap either! No one tell you about how much the coolant or the power steering fluid will cost when you buy the vehicle!
Old 09-03-2008, 01:53 PM
Zerb Zerb is offline
I found it in my area (Portsmouth NH) in -2- stores - it's caslled CHF-11 and is in a green square can priced at $24.00 <stuff is made in Germany>
