Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-08-2008, 06:30 PM
spizzoti996 spizzoti996 is offline
92 regal 3.8
well i tried running the codes today.
it seems to flash 1,2 several times
then 4,1 several times and the repeat the process.
rough idle, worse mpg, maybe less power, 120k, properly maintained.
should i remove the neg. cable for a bit. clear the codes, run it. and see what more codes show up. it's the 1,2 that is confusing me.
Old 02-08-2008, 08:42 PM
Mickey#1 Mickey#1 is offline
Re: 92 regal 3.8
It'll always flash 1,2 (Code 12). It does that to confirm the system is working correctly.
Old 02-10-2008, 06:10 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 regal 3.8
Code 41 could indicate several different things! First thing to check is the cam sensor and the cam sprocket magnet. In addition, do not rule out the crank position sensor, as that can also set this code.
