Old 02-08-2008, 09:54 AM
Mammlouk Mammlouk is offline
CV Axle - Replace or Re-Boot
Does anyone here have experience repacking/booting CV axles? I've replaced them before, but never repaired one. I was thinking that I'd like to give it a shot and save some money.
Any tips on getting it done? What signs should I check for in the joint to decide if there's too much damage? I don't want to waste time with doing the boot if the joint is already damaged.
Thanks,
-Jeremy
Old 02-08-2008, 10:00 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: CV Axle - Replace or Re-Boot
CV axles are cheap, just replace it and save yourself the hassle..
Old 02-08-2008, 10:07 AM
I know they're only like $60 - $70 each, but I don't feel like spending $120+ to take care of both. I guess if everyone says it's not worth the hassle, then I will just replace though.
Old 02-08-2008, 10:12 AM
Kind of a Big Deal
Yeah, and if you get them from AutoZone, they come with a lifetime warrenty... so next time they wear out... just bring them in and get new ones
Old 02-08-2008, 10:16 AM
Really? Even though they are a remanufactured part, and they are expected to wear out, they will just replace them later? If that's the case, then I guess I will go that route!
Old 02-08-2008, 10:17 AM
Kind of a Big Deal
I would talk to Autozone to find out EXACTLY what that "lifetime" warretny covers... but i believe so.. Whenever i snapped an axle in my honda they just replaced it....
Old 02-08-2008, 10:31 AM
Sounds good. Thanks for the info! While we're on the topic, I have another question. Is it required to drain the transmission fluid for the axle replacement? It seems that the how-to's I've seen for this car list it as being necessary, but when I did axles in my old 92 Corolla I never drained the fluid and it wasn't an issue. Any clarification would be great.
Old 02-08-2008, 10:32 AM
Kind of a Big Deal
if you dont drain it... some may leak out... not a biggie as long as you top it off when finsihed
Old 02-08-2008, 10:35 AM
That's kinda what I figured. I just wanted to make sure there's no strange thing on these civics where I'm going to have tranny fluid come pouring out on me
Old 02-08-2008, 10:48 AM
Kind of a Big Deal
I used the term "some" loosely.... it all will depend on how much is in there to begin with
Old 02-08-2008, 11:11 AM
So I guess I should just go ahead and drain/refill for the job then. I guess I will wait and do it when I am going to install the new tranny then, since it won't have any fluid
Old 02-08-2008, 11:18 AM
Kind of a Big Deal
DO what you will... a drain and refill is no big job... and can only hepl the drivetrain in the long run
Old 02-08-2008, 01:04 PM
Well, since I'm not even driving the car right now and I will probably just drive it from my house to the garage to put in the tranny, I figure it's not critical to get the CVs done before then.
Old 02-08-2008, 03:43 PM
tepco tepco is offline
Yea, i would replace them.
I have a reciept right in front of me which says "Limited Lifetime Warranty" which i have used for my brake pads which they also warranty for life. When i wear them down, they replace them for free for life.
BTW: the axcel cost me $59.99, and if the boot is ripped, it most likely has been driven with limited grease, so i would replace.
Old 02-08-2008, 04:18 PM
Sounds like a good deal on those warranties. New axles from AutoZone it is!
