Old 02-23-2003, 06:05 PM
bshown bshown is offline
Paint Jar Problems
Just picked up some tamiya acrylic paint jars. one problem though. the lids don't come off! they have never been opened and are on there extremely tight. can someone give me a tip to loosen the lids so i can get them off.
thanks
Brandon
Recently Completed
Toyota Supra-Arctic Blue Metallic with blue/grey interior
Toyota Tom's Castrol Supra
Toyota TS020
Old 02-23-2003, 06:10 PM
64 Chevy 64 Chevy is offline
Put the lid of the jar in some running warm water. That should expand the metal enough to get the lids off.
These are metal lids right?
Why can't I think of any thing clever to put down here?
daggerlee's Avatar
Run them under hot water for a few minutes. Use a shirt or towel to twist them off later. If you have a small enough one, you can use an oil filter remover. A pair of pliers might also do the trick, but use caution.
Never had a problem with my new Tamiya paint bottles before. They come off real easy when new, it's after you've used them for a while that they start to get hard to open. Maybe your bottle was a returned one that someone had used?
Also, to avoid the problem in the future, stir your paint instead of shaking it. That way the paint can't get into the top of the bottle where it dries and makes it hard to open.
Dan
Old 02-23-2003, 06:11 PM
daggerlee's Avatar
No, they're plastic. Tight lids in Tamiya's case are usually caused by dry paint sticking between the jar and the lid. The warm water sort of 'melts' the paint.
Dan
GTi-VR6_A3's Avatar
GTi-VR6_A3 GTi-VR6_A3 is offline
H4X0R T0 T3H M4X0R
Send a message via AIM to GTi-VR6_A3
you ever see that neat wrench that is like arubber belt. use on of those and use it to hold the bottle then twist the lid with hand. thats how me and my friend got it off. btw it was a plastic lid
-GTi-VR6_A3
-GTi-VR6_A3
Old 02-23-2003, 06:16 PM
plastic
mine are plastic. i'll try the hot water. the ones that i have opened and used i've had no problems getting them open months later. it's the ones i haven't been able to open since i bought them that i'm having trouble with.
Recently Completed
Toyota TS020
Old 02-23-2003, 07:03 PM
ShOrtyOC714's Avatar
ShOrtyOC714 ShOrtyOC714 is offline
=p
Send a message via AIM to ShOrtyOC714
Its happends to me too, with my Testors Acrylic Paint. Just get a cup of HOT water and put the paint jar upside down into the water for a couple of min, then take it out and it should open easly.
Old 02-23-2003, 07:14 PM
935k3's Avatar
935k3 935k3 is offline
Vise Grips do wonders on stuck lids,but set them carefully or you can crush the jar.
Old 02-23-2003, 10:40 PM
2000-redrider 2000-redrider is offline
Try putting a few drops of thinner into the seam of the lid and jar. Then turn the jar upsidedown. After a few minutes, the thinner should help loosen the dried paint.
To prevent this from happening again in the future. Always wipe the rim clean before putting the lid back on. Also, covering the jar with a piece of cellophane before putting the lid on helps.
Old 02-23-2003, 11:07 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
That's because testors lids are metal.
I tried a vise on a Tamiya bottle, the cap slipped. I just put all my strenght (did I spell that right?) into it and after about 5 seconds of giving it full stenhgt, the bottle opens. GIVE IT ALL YOU GOT !!!
If that does'nt work, hit it from the bottom with the face of your palm while the cap is wet like recomended before. If all else fails, slam the paint on the ground ans scoop up as much paint as you can!
Old 02-24-2003, 12:29 AM
chaos's Avatar
chaos chaos is offline
AF Premium User
Try using rubber gloves - you know, the ones for household chores, etc.
Works for me.
acrylic paint stripping problem KTem Car Modeling 8 07-28-2005 04:47 PM
paint\priming problem Austin Glass Mustang Problem Diagnosis 1 04-07-2005 06:05 PM
Painting / Finish Problems Captain Mark Car Modeling 5 03-27-2004 06:42 PM
Paint job problem Ghost_9418 Car Modeling 10 03-21-2003 01:54 PM
Paint quality problems with Maxima joeyg Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 15 11-02-2001 11:23 AM
