Old 02-07-2008, 01:22 PM
natem natem is offline
map sensor not conneced 97' lsi
I just purchased a 97' LSI 1.3 and I am getting code p0106 which points to the map sensor. I located the sensor mounted on the firewall and the vacum hose that comes out from it goes to a metal hose on the firewall, but then that ends up not going anywhere. there is a bracket at the end of where that hose goes, but there isn't anything there? Where is this hose supposed to go from the sensor?
Old 02-08-2008, 05:39 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: map sensor not conneced 97' lsi
It should hook up to the intake manifold somewhere. Should be a diagram stuck to the inside of the hood.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 02-09-2008, 10:22 AM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
it sounds like you have a hose going the wrong way. I'm not exactly sure of the '97's but the earlier ones had a hose going from the intake manifold and going directly to the MAP sensor on the firewall. Yours may possibly be missing a hose from the metal portion, going to the intake manifold. You may also unplug the MAP sensor hose from the metal hose and see if it will reach to the connector on the intake manifold. The connector on the intake should be found under the throttle body assembly, pointing toward the firewall.
