| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
transmission issue..
today i test drove a 97 GST manual trans and minor mods.. .. my main concern was while letting the car warm up noticed that there is no "stopper" on 2nd... it just tries to go in without touching the clutch and grinding..
Now when driving the car there is no smooth transition from 1st to 2nd... it always gives a quick grind before entering??? what could be a couple reasons for this? and is it an expensive fix?
96 Eclipse GS Stock 98 Eclipse GST Stock |
Re: transmission issue..
Could be the throw out bearing going back or bad syncros. Either way you're going to have to drop the tranny.
What do you mean by stopper? I can technically put my car in any gear without hitting the clutch (only done with it off).
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Im going to guess the syncros are going out on 2nd. I can shift without the clutch to. As long as you dont try to slam the gears without pushing the clutch there is really no harm.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Quote: Originally Posted by SilvrEclipse Im going to guess the syncros are going out on 2nd. I can shift without the clutch to. As long as you dont try to slam the gears without pushing the clutch there is really no harm. relitively when should i shift without the clutch... so what your trying to say is a little grind ain't that bad? clarify
RPM shifting is easy and usually if done right there will be no grinding. If 2nd is important to you but you dont have the finances for a rebuild just take 1st up to about 4000 rpm and then push it down into second firmly and eventually it will find the sweet spot and pop right in and keep going.
2004 Mazda 6i 1997 Tahoe |
I dont recommend you shifting with out the clutch. While its not really bad for the tranny IF done properly. If you dont do it right it could screw up your tranny. A little grinding isin't going to hurt anything really, but if your shifting right it shouldn't grind at all.
