Old 02-07-2008, 10:25 AM
labmik labmik is offline
break oil leak
Need guide/assistance in to how to change the break oil line from the master cylinder to the rubber hose line connected to the front wheels for the dodge grand caravan 1996 , what is the possible length and the size of the fitting
thanks
Old 02-07-2008, 08:56 PM
tempfixit tempfixit is offline
Re: break oil leak
Sorry I do not know size or length of lines. Are the lines completely rusted or is there just a hole? If just a hole can you use a small pipe cutter and flaring tool to insert pieces to repair leaks? Is this preventive maintenance?
To replace complete lines you will have to get multiple lines ( I believe there are 3 feet in length) and splice together (don't forget the male threaded connectors to couple togther), along with pipe bending tools to bend line appropriately. I doubt if you can get prefabricated lines at parts stores or stealerships. Should not be tough task but will be time consuming.
Good Luck
