Go Back   Automotive Forums Car Chat > Honda > Locations (USA, Canada, Asia, etc...) > California
California California regional information. Events, Shows, Ect...
Old 02-23-2003, 05:07 PM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
i need power!
For now i'm running a '98 civic with nothing under the hood but the stock engine. What's the first mod that i'll really get my money's worth? I heard a cold air intake isn't a bad start, but i dont want to spend a couple hundred. Any ideas?
Old 02-23-2003, 09:50 PM
RedY2KCivic RedY2KCivic is offline
Yea, a cold air intake is definately a good first step. But if you want something that is going to make a significant difference, you're going to have to spend at least a couple hundred.
Making cars quick isn't cheap.
Lady PH member since June 2000
Proud Member AF Cali Crew --
Nor Cal Chapter
Old 02-23-2003, 09:56 PM
ok, then what's the best way to do that? I mean spend a couple hundred and make a big difference?
Old 02-24-2003, 01:43 PM
DarknessRS's Avatar
DarknessRS DarknessRS is offline
Send a message via ICQ to DarknessRS Send a message via AIM to DarknessRS
There is only so much you can do to increase your performance without spending money. Off the top of my head, you can advance your timing, cut out the catalytic converter, and do some weight reduction. Of course none of this is legal, since your car will fail emissions and fail a safety inspection of you do any of the above.
A couple of months ago I remember seeing an article in an import mag (I forget which one) where they completely trashed a Nissan Altima or Maxima to make it go faster. They cut off a lot of the frame and removed everything to make it very light and I believe it was over a full second faster than the stock version. It was pretty mangled though, so I recommend spending money for performance gains.
Current obsession: Subaru Impreza WRX STi Version V (GC8)
Most wanted mod: Honda F12X Turbine, SR20DET, B20A
Zero purojekuto chi-mu ~
Old 02-24-2003, 02:11 PM
uh..ok
Ok, i'm planning to stay legal if that suprises anyone. Basic engine mods that i get my money's worth. I don't know much about the engine and what to take out or where to add stuff. I leave that up to someone else until i learn the specifics. What kind of air intake is the best to start with here? Any increase in power is a good one. Someone give me ideas!
Old 02-24-2003, 03:51 PM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
oh my god.. lindy is it really you...????? my eyes decieve me..
where the heck have you been.. why haven't you called.. and why haven't you moved..
anyway whiteracer.. mods cost money.. bottom line.. there is no cheap way.. especially under 100 unless you wanna go homemade..
goodluck.. and start with the cai
S2000
Old 02-24-2003, 04:52 PM
ok, anyone got any ideas of which brand or where to buy it around pasadena? or a link to a website and which one i should get?
Old 02-25-2003, 01:22 AM
THE4TH's Avatar
modacar
lightning
aem
autocarparts
S2000
Old 02-27-2003, 01:08 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
He could pull his A/C and P/S that helps a little bit but I do advise against body kits and under light kits.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 02-27-2003, 01:14 PM
any reasons you or anyone opposes to either one of those two?
Old 03-02-2003, 01:01 PM
DarknessRS's Avatar
A body kit isn't a worthwhile investment unless you want to enter it into a show.
1. They usually cost $700-1000, paint and install are about another $500-1000 depending on whether you want it moulded or not
2. If your car is already very low, you'll scrape that kit on everything and it will eventually crack or break somewhere.
3. With a Honda, somebody nearby probably already has that same kit, unless you got yours straight from Japan.
Underbody lights are illegal to use on the streets, so its another one of those show items. Not to mention the whole ricey reputation they got after Fast and Furious.
Old 03-03-2003, 11:52 AM
Sorry I just get upset when a bunch of people put on kits and underlights because it makes us real Honda Tuners looks bad. Then we end being called Ricers when our cars are hella clean and nice looking. It just makes me upset sorry.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
need power help!!! dredinyonkers '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 25 07-14-2004 10:51 AM
83 civic needs power cabledesign '71-'87 Civic | CRX 10 03-13-2004 12:33 PM
all wheel drive toyota camry needs power! Tactics Camry/Camry Hybrid/Vista 6 03-04-2004 03:23 AM
Need power window/door lock install help. wheel1856 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 05-27-2003 08:02 PM
