Old 02-06-2008, 09:01 PM
taliesin3x3's Avatar
taliesin3x3 taliesin3x3 is offline
Send a message via ICQ to taliesin3x3 Send a message via AIM to taliesin3x3 Send a message via MSN to taliesin3x3 Send a message via Yahoo to taliesin3x3
What is required for a front end lift?q
2004 Silverado 1500.
You know these trucks are lower at the front than they are at the rear? What is required to lift the front end up to more or less match the rear height?
Old 02-06-2008, 09:39 PM
bigbadram51 bigbadram51 is offline
Re: What is required for a front end lift?q
2wd or 4wd.... there is a difference... 2wd you can get longer spindles, if its 4wd, you can normally just crank the torsion bars to get it level... If you cant crank that much you need to get Ford (higher indexed) torsion bar keys. Trouble with cranking the bars you need an alignment afterwards and it will ride slighty rougher. fairly easy to do and with stock tires you can fit a 33" tire easily on stock wheels
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 02-06-2008, 11:57 PM
2WD... Sorry, I should have mentioned that!
Longer spindles... sounds expensive!
Old 02-07-2008, 12:26 AM
Longer spindles will give you more than you are looking for (height wise). You could go with the Daystar coil spring spacers.. heres a link http://www.suspensionconnection.com/.../KG09101L.html
3" PA Body Lift
Covermaster Top
Old 02-11-2008, 11:27 PM
Thanks for the info!
Yeah, I'm only really interested in balancing the look from the side... you know, levelling the front up with the rear - if it doesn't cause handling issues.
These coil spacers look to be the ideal thing. Installation looks to be a major pain in the nether regions though!
Old 02-13-2008, 05:16 PM
kahjdh's Avatar
kahjdh kahjdh is offline
On a 4x4 where do I get the 4x4 keys and how much do they run?
Sorry to highjack the thread but I didnt think it was worth another one
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-13-2008, 08:53 PM
Easiest way is to go down to your local Ford dealership and get their TB keys. You can order them from a ton of places on the "interweb" (sorry 30 Rock joke). Depending on how much you crank, you will need an alignment and maybe a little bit longer shock to get back some of the soft ride.
3" PA Body Lift
Covermaster Top
Old 02-13-2008, 10:18 PM
ohhh.. and you can pick them up from anywhere between 70 and 100 bucks
3" PA Body Lift
Covermaster Top
