Old 02-06-2008, 05:49 PM
justins_s10 justins_s10 is offline
Engine Shakes after Warming Up
What would cause my engine to shake in my truck after it reaches operating temperature. I brought it to my mechanic, and he scanned the computer, and it said the EGR valve was bad. So I had them replace that along with the solenoid. I changed the plugs and wires 6 months ago, so those should be find. It runs and drives great when you are moving, but while idling it shakes the whole truck, and surges foward at times at red lights. It is a 91 s10 4.3 auto with around 110,000. Any Ideas??
Justin
Old 02-06-2008, 11:46 PM
dragon_kin01 dragon_kin01 is offline
Send a message via Yahoo to dragon_kin01
Re: Engine Shakes after Warming Up
ok here u go. http://www.autozone.com/servlet/UiBroker this is a small description of what the problem may be. check all that apply to u. also, check motor mounts (i know that it would shake all the time, but its worth a try) trany mount. also, a clyinder may NOT be firing or the injector to that cylinder may NOT be getting fuel. try all of these and get back to me.
FORD - Found On Road Dead, ****ed Over Rebuilt Dodge, Flip Over to Read Directions, Fix Or Repair Daily,(backwards) Driver Returns On Foot (it shows I hate ford)
Old 02-07-2008, 11:57 AM
j cAT j cAT is offline
Justin
use vacuum gauge and check for leaks. vacuum should be greater than 19in at idle. pcv hoses highly suspect
