Old 02-06-2008, 03:28 PM
Corey170 Corey170 is offline
Subs cutting out
i got an 89 nissan 240sx hatchback with 2 12' type R's and a massive rs50 amp. anyways, my subs periodically cut out (for some reason usually they come back on when im breaking). Also, when i lean on the sub box they are on, but when i stop leaning they turn off. I checked the connection to the outside of the box and it looks fine. could it be a connection inside the box? thanx
Theres always something wrong with every car.. ALWAYS
Old 02-06-2008, 07:42 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Subs cutting out
how are the subs wired inside the box (series, parallel, etc ...). It could be that the speaker wires are loose and short out the amp when the box is moved to different angles.
Old 02-06-2008, 08:04 PM
I dont know how theyre wired. (although i did when i got them over a year ago). Maybe ill try oppin everything out and take a look inside. The little knobs that the speaker wire attaches to (on the box) have a hole perpendicular to the knob. do i need to stick the wire in that hole then down the knob?
Old 02-07-2008, 12:47 AM
AWP9521 AWP9521 is offline
Yes, the wire goes in the hole then you tighten it down and that makes the connection.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 02-07-2008, 03:34 AM
never mind i fixed it. turns out the connection was bad inside the box. electrical tape works wonderss
