Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 02-06-2008, 09:44 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
SS Line Connector
Just quick question. I have some SS line going from the thermostat housing to the coolant tank (since I don't have the actual hose that used to be there) and it fits perfect and I have clamped at the housing, but it's a little too big at the tank itself. It's a little loose. I have a small C-Clamp and T-Clamp on it but being SS Line, it's not shaping to the nipple right so it leaks a little. Is there anyway to stop it from leaking without making a new top from metal and welding SS connectors on? Any ideas? I have to stop the coolant leaking issue. It's always something. It pisses enough just to get on the alternator and cause the belt to slip.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-06-2008, 10:55 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: SS Line Connector
What do you want to clamp Dave?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-06-2008, 11:04 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The ss line on the coolant tank. I would try getting some heat shrink tubing and put that on the nipple, that would build but the nipple some and might be enough for the SS hose to connect to. You may have to put 2 pieces on there.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
david-b's Avatar
Dave is THAT guy
Originally Posted by david-b
...I have some SS line going from the thermostat housing to the coolant tank and it fits perfect and I have clamped at the housing, but it's a little too big at the tank itself. It's a little loose.
75 Monte Carlo
Old 02-06-2008, 11:06 AM
david-b's Avatar
Dave is THAT guy
Cool. I was thinking like electrical tape or something but I know that wouldn't last. I always forget about heat shrink tubing. Should snug up the fit a little.
75 Monte Carlo
Old 02-06-2008, 11:10 AM
Holset powered 420a
Electrical tape wouldn't work for shit. I would try the heat shrink, it should work, there is not pressure on that connection. Other than that you just would have to go buy the right size rubber hose. Do you like the look of the SS hose and thats why your trying to keep it?
98 Eclipse GS Turbo
2001 BMW 325i - DD
JoeShmoe's Avatar
Slap some damn sealant while you're at it. Wait, nevermind........boiliing engine coolant.........no sealant. Sorry just thinking out loud man.
Old 02-06-2008, 11:15 AM
david-b's Avatar
Dave is THAT guy
Was making use of what I had. I had this aftermarket coolant tank that ended up pissing me off so I may have taken it off and threw it up against a brick wall and shattered it. So as a result, I went back to stock, and got everything except a stock hose for that part. I got lots of SS line laying around, so I used that. Looks decent too.
75 Monte Carlo
Old 02-06-2008, 12:49 PM
Holset powered 420a
Can we get a pick? Im just curious as you how it looks. Im sure it looks pretty good. Now you just need to get an SS line going to the radiator
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-06-2008, 12:57 PM
david-b's Avatar
Dave is THAT guy
The car is going to be under 14 inches of snow when I get home tonight, so no pic for awhile. I was thinking the SS to radiator, but then I have to weld on fittings, or get that fake cover crap that I hate. I'm going to do my power steering in the SS also when I redo that and get that working.
75 Monte Carlo
Old 02-06-2008, 01:09 PM
Holset powered 420a
Man that sucks. It was 73F here, I got to enjoy riding around with the windows down and sunroof open. Just like summer time
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-06-2008, 01:23 PM
david-b's Avatar
Dave is THAT guy
You-> <-Me
That's what it feels like when you tell me that.
75 Monte Carlo
Old 02-06-2008, 01:26 PM
Holset powered 420a
That just means you need to move down to the south. Its so much better here.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-06-2008, 01:33 PM
david-b's Avatar
Dave is THAT guy
Why so I can get an accent? Pass. I'll take my snow thank you. Just sucks trying to get to work in it. My pants are filthy from this morning. Major ice storm this morn.
75 Monte Carlo
Old 02-06-2008, 01:50 PM
Holset powered 420a
Just learn to say yall alot and you will fit right in.
98 Eclipse GS Turbo
2001 BMW 325i - DD
