Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 02-06-2008, 09:19 AM
Intrepidgirl Intrepidgirl is offline
Subframe bushings
Help!!! My husband was trying to change the subframe bushing on the front passenger side and the weld from the washer above subframe broke and bolt head snapped off. Bolt just spins. My car has been down for almost a month now and I need sugggestions on how to get bolt out.
Old 02-23-2008, 09:44 PM
ninemmeter ninemmeter is offline
Send a message via Yahoo to ninemmeter
Re: Subframe bushings
I'm getting ready to do my friends Intrepid on the 1'st or 2'nd of March. If you haven't got yours fixed by then then I will see what it looks like it will take to do it and let you know. I'm sure it won't be too hard. Have a great day!!!!!
Old 06-26-2009, 11:03 PM
johnh1969 johnh1969 is offline
Where did you get your subframe bushings? Im having trouble finding them for my cousins 1997 Intrepid! And how much do they run?? Thank you for any help.
Old 07-09-2009, 04:13 AM
BigJL71 BigJL71 is offline
Smile Re: Subframe bushings
Try your local NAPA auto parts store, they have a kit(2 pc.) for $69 and change. The only other option is a dodge dealer (and they are real expen.) good luck...
Old 01-12-2010, 06:51 PM
reb9201 reb9201 is offline
Hi, I am in the process of doing the same... All the sub-frame bushings I have found online were for 1 set (1 upper and lower piece) and usually ran around $55.00 each. For 1 bushing...there is the upper part and the lower part, making 1. So, if buying them individually, would be around $220 for all 4 and you usually have to end up using your own steel cups they fit into.
I got lucky and found this website and it is a set of 4 uppers and lowers and we would still use the steel cups from our car, but they are only $139.00 for all four! Here's the link: http://polybushings.com/pages/LHMounts.html
The poly bushings are better than the "poly-foam" mounts the dealer has and actually makes a quieter ride!
Hope this helps!
