Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 02-06-2008, 08:11 AM
'90 Escort Man '90 Escort Man is offline
AF User
2001 Villager AntiKnock Sensor
I have thrown a bad anti-knock sensor code in the computer, and the part cost $117. This is painful, and I have sensed in past threads that this is not an important sensor. Is it possible that the sensor is still good, but maybe I can run a higher octane fuel to reduce the knocking and have the sensor reset? I had a local auto parts store clear the code, but within 10 minutes of driving, it came back. What should I do?
Thanks for any advise that you can provide!
Old 02-06-2008, 10:19 AM
tempfixit tempfixit is offline
Re: 2001 Villager AntiKnock Sensor
Here is info that I think will be helpful for you:
http://f1.grp.yahoofs.com/v1/cMupR7n...%20Sensors.pdf
Any other codes??
WHen was last tune-up??
Like you stated the knock sensor rarely fails, usually another code is set with it.
Check oxygen sensors
Clean MAF Sensor
Old 02-06-2008, 10:33 AM
AF User
Tempfixit, thanks for the reply! There was another code, but it was for a sensor that this particular auto parts store did not carry. I will have the codes reread and see if anything else is thrown.
This van has 108,000 miles, and I replaced timing belt, plugs, cap and rotor at 103,000. I didn't replace wires.
The link you posted doesn't work, I even tried cutting and pasting.
Thanks again for the reply!
Old 02-06-2008, 10:55 AM
Always remember that a code does not mean that a sensor is bad, it is a intication as where you start diagnosing.
