Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-06-2008, 07:57 AM
klvaleri klvaleri is offline
Pulley Noise
Hi Guys,
My Rodeo's pulley making so much noise first cold start up than as it warm up the noise went away. It's been doing it couple weeks and now it got worse that scare me to drive it. I'm in cold state "MN" I tried to find out which one of pulley cause the noise but couldn't pin it down. I replaced serpentine belt about two months ago and idle pulley about two years ago. Can any of you suggest it to me which one of these pulleys are common cause or failure. It has about 133,000 miles. Thanks in advance.
1999 RODEO LSE 4WD V6 3.2L
Old 02-06-2008, 09:21 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Pulley Noise
Typically it it the upper pulley. I've had noise when it is cold too (I'm in WI). Last year I have the upper pulley replaced and I think some of my cold pulley noise went away.
This is the most common one to make noises.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-06-2008, 10:17 AM
Re: Pulley Noise
which one is it that you refered to. I can't get the diagram in this.
Legend
(1) Crankshaft Pulley
(2) Cooling Fan Pulley
(3) Tensioner
(4) Generator
(5) Air Conditioner Compressor
(6) Power Steering Oil Pump
(7) Serpentine Belt
Old 02-06-2008, 11:52 AM
Isuzu Guy
Re: Pulley Noise
-Ryan
Isuzu Moderator
Car Show Tips
Old 02-06-2008, 12:18 PM
Re: Pulley Noise
Thank very much amigo-2k.
Old 02-06-2008, 02:45 PM
vilos vilos is offline
Re: Pulley Noise
Number 7 is correct. I believe it's called the Idler Pulley. Autozone has a cheap plastic one for about $17. It takes about 5 minutes to replace it. I'm surpriised you got 133k out of it.
vilos
2000 Rodeo LS 2WD 3.2V6
Old 02-06-2008, 03:13 PM
Re: Pulley Noise
The OEM work until January 2005 and than it seize on me on my way to work about two years ago. I replaced it with a plastic one from NAPA now it made so much noise. I have to replace tonight. Thanks.
Old 02-10-2008, 12:10 AM
rexbest rexbest is offline
Re: Pulley Noise
Mine is making the same noise with 115k miles. Replaced the idler pulley,,still had noise. Tried to replace the tensioner pulley but none of the parts stores have it listed as the tensioner pulley. Found one online that I will order, but if that is not the problem, does anyone have other suggestions? Vacuum? Gasket leak?
Old 02-10-2008, 09:22 AM
Isuzu Guy
Re: Pulley Noise
Is the water pump still original?
-Ryan
Isuzu Moderator
Car Show Tips
Old 02-11-2008, 01:35 AM
boritz's Avatar
boritz boritz is offline
Re: Pulley Noise
Try removing the serpentine belt and then running the engine.
Has the noise gone? Stop the motor and turn each of the pulleys by hand and check for noise or roughness. The noise is somewhere in the serpentine belt train.
Was the noise still there? Then it *could* be a pulley in the timing-belt train behind the front covers, as hinted at by amigo-2k above.
Old 01-29-2009, 11:13 AM
batsfordinner batsfordinner is offline
Re: Pulley Noise
My 99 rodeo v6 upper idler pulley has been making noise for about the last 6 months, although I wasn't sure that was the problem until now...it just locked up with 98k miles on it.
are the only readily-available units plastic? I know if I have to get this from the dealer it may take a while (if they have to order it) and cost much $$.
Old 01-30-2009, 06:38 AM
Re: Pulley Noise
Why don't you try this place:
http://isuzu.stcharlesauto.com/Default.aspx
