Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-05-2008, 05:41 PM
kgarcia kgarcia is offline
car shakes while stopped
2001 - shakes when stopped.. service engine soon light now blinks on/off
Old 02-05-2008, 10:50 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: car shakes while stopped
Take it to auto zone and have them scan it for trouble codes. Its free.
1969 Cougar
357w & TKO - 475hp
Old 02-07-2008, 08:59 PM
stevenhess stevenhess is offline
motor mount or transmission mount? my grand am did the same thing
94 Mustang GT 5.0L converted to a edelbrock intake manifold and edelbrock carburater, o/r H pipe with flowmaster 40's, 17 in cobra r wheels, msd package including coil and distributer, ford racing vavle covers, steeda short throw shifter, king cobra clutch, T5 3:55 geared transmission, and a non-slip poze rear end!
Old 02-08-2008, 10:55 PM
kaos2tru kaos2tru is offline
BLINKING CHECK ENGINE LIGHT = SERIOUS PROBLEM
It is without a doubt a misfire. If you have it checked out your gonna probably get a po30X code (x = 1-8) it will tell you which cylinder is misfiring.
Old 02-12-2008, 04:46 AM
r2d2yoda r2d2yoda is offline
the reason your car shakes while stopped is mounts or o2 sensors or fouled plugs broken vacuum line it could also be you knocked your balancer into a different position from gunning it alot check the ballencer last light blinking is emissions you need your computer checked or clear it and see if it comes back on,i know this because i have a 99 mustang that vibrated heavely inpark and drive it ended up being the ballencer
Old 02-13-2008, 09:40 PM
82Stang 82Stang is offline
If you can't get to an auto parts store to scan it, then unhook the pos and neg terminals of the battery for a few minutes. Then restart. Sometimes this can reset the comp and clear the codes, but a major fault will return anyway. So, getting a scan will be your best bet for anything 96 and up.
Not having the car to look at, I'd check things like the plugs, wires, cap n rotor (if applicable), coils etc. I'd check the electronic things first then the motor mounts etc. Chances are it's misfiring/skipping. So make sure it is tuned up first.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
