2000 Jimmy...wont start
I have a 2000 GMC Jimmy 4.3....The issue is it will not start, engine does crank over, I did change the rotor...still wont start...I do have spark out of the coil and out of the spark plug wire. I do hear the fuel pump running when I turn the key on, I even poured some gas in the throttle body...with no luck...I guess I'm down to ignition control module or my timing is off. The truck up to now has been running great...does anyone have any IDEAS
Re: 2000 Jimmy...wont start
Test your fuel system pressure. There's a test connector port on the fuel rail near the firewall. With key on, the fuel pump should provide at least 60 psi and be able to hold it. Low pressure may be a sign of a bad fuel regulator. Dropping pressure is a sign of a failing fuel pump return valve. If you have lots of miles on your truck, changing the fuel filter might be a good idea too.
Timing can be easily checked using a timing light, but relies on crankshaft, IAT, and other various sensors to determine the correct advance. Failure of those sensors should cause a code to be stored in the ECM, but may not illuminate the SES light. Hook up a OBD code test tool to read any stored codes.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Are you getting spark from all six of your spark plugs? Sounds like an ignition problem if you poured some gasoline down the intake and got nothing.
"When I was a kid my parents moved a lot, but I always found them." Rodney Dangerfield |
i have same problem as this and i replaced and tested fuel both are great and i even timed it and place a new coil but no spark i none of the plugs and it wont start i also need help
one nice thing about the ICM, is that it is the same on many chevy's. it is even interchangeable between v6's and v8's. O'reilys auto parts can test them, but their system sucks.
the best way to test it is to swap it with a known good and see what happens. i know my 2001 blazer has the same ICM as a 96 LT1 trans am, so i would assume that 96-early 2000's are the same. you can also cross check the part number at autozone to be sure.
2001 Chevy Blazer 4.3L 5 speed manual Alpine deck, Type R 12in. sub. 145k miles 1997 Pontiac Sunfire 2.2L automatic trans 146k miles |
