Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-05-2008, 04:27 PM
Gsst98's Avatar
Gsst98 Gsst98 is offline
Send a message via AIM to Gsst98
Radiator hoses leaking
My 98 GST both upper and lower radiator hoses are leaking where they connect to the engine. Whats the best way to stop this? I cleaned the all the gunk around both hoses that connect to the engine, I really need a solution that will last another week until new hoses come. Also the radiator fluid was bubbling and smoking last night spewing everywhere, Im not sure if this is a bigger problem or its just cause the hoses are leaking and everything was hot, the car though did not overheat the temp gauge read normal.
Old 02-05-2008, 04:32 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Radiator hoses leaking
I think your clamps are not tighten ing anymore. I would recommend replacing those right away.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 02-05-2008, 05:32 PM
steviek's Avatar
steviek steviek is offline
but both of them at once it just doesn't make too much sense. Its lucky its just rad fluid your losing and can easily be topper off. The clamps are easy to replace if that works thats great. I mean theres not a lot of sophistication around the hoses they just transfer the rad fluid back and forth from the radiator. Any heat resistant tube and clamp will work for them. Just be use your ingenuities clean around where the hoses connect so it forms a good seal then use whatever you need to tighten them down (t bolt clamps if you have to).
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-05-2008, 06:49 PM
kjewer1 kjewer1 is offline
AF - Advisor
A common cause for leaky radiator hoses is corrosion on the aluminum pipes the hoses connect to. You can clean it up with some sand paper or emery cloth. If it's real bad you can just replace them. The water neck is only like 30 bucks IIRC, and you can replace the tstat while you're in there. The large water pipe for the lower hose is a little more trouble and a lot more money, so hoepfully that one cleans up well (it always does).
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-05-2008, 07:45 PM
Gsst98's Avatar
Thanks for the help the top clamp is basically broken. I tried moving it and it wont tighten back down ill jsut T-clamp it and see how it does.
