Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-05-2008, 03:01 PM
00RodeoLS 00RodeoLS is offline
120K Maintenance
Hello all. I just clicked over the 120,000 with no problems. I am starting to get the maintenance done. So far I have changed:
Timing Belt w/ water pump
Coolant
Rear diff fluid
Tranny service
Power steering flush
Replaced Idler Pully
Replaced Serp belt
Replaced PCV Valve
Air Filter
Oil Change
I have new tires on the way because I know i need them here soon.
Is there anything else that I am missing or should replace?
I am going to have my brakes checked, but I think they are okay.
If there is anything I am miss please let me know! I have the money and want to keep this things running like it should!
Thank you in advance!
2000 Isuzu Rodeo LS 4x4
2 Rockford Fosgate 12" Subs
Fosgate 401S Amp
Old 02-05-2008, 03:54 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 120K Maintenance
fuel filter
s-belt tensor
upper and lower rad hoses
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 02-05-2008, 07:24 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Wheel bearings maybe. I usually just replace them instead of repack if they are old.
Might think about ball joints. Not sure how long they usually last, I always end up with split boots which get junk in them and kill them.
Check the cv boots closely, if they are starting to crack you might think about replacing them.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 02-05-2008, 11:50 PM
Isuzu Guy
It might be worth changing the front O2 sensors too (even if it helps 0.2 of a MPG it would pay of quick with todays prices of gas).
-Ryan
Isuzu Moderator
Car Show Tips
Old 02-06-2008, 04:45 AM
Tom01Rodeo Tom01Rodeo is offline
You'll want to check your timing belt idler pulleys also. I just did my TB two months ago at 110K and one was a little rough, so I replaced both. Actually, I just pressed the bearing out of both and replaced it, much cheaper. Search my other posts for bearing pt# info.
Old 03-18-2008, 11:19 PM
Funny that you guys just knew that that CV boots were cracking. Not a few days after I wrote my first post, I noticed that I had a bunch of grease in my wheel wells. I got someone to replace the for me for $390 including parts. I am not too familiar with wheel bearings. Everything else is okay I think. I have been getting crappy gas mileage, but it's the winter blend.
Thanks for all the help!
Fosgate 401S Amp
Old 03-18-2008, 11:33 PM
Isuzu Guy
about all you can do for MPG is to air up the tires, clean out the MAF, reset the ECU, and keep the PCV and EGR system clean (and take it easy on the skinny peddle).
-Ryan
Isuzu Moderator
Car Show Tips
