Old 02-05-2008, 01:45 PM
lenny162 lenny162 is offline
99 blazer wont start
I have a 99 Chevy Blazer i let it sit for about a month without driving it the battery went dead so i charged the battery when i try to start it, it wont start it will turn over and thats it. while im trying to start it it is turning over when i turn the key back it acts like it wants to start for a sec then dies
Old 02-05-2008, 01:59 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 99 blazer wont start
Check for lose of fuel pressure or spark to plugs.
Make sure there is plenty of gas in tank.
Can you hear fuel pump run or prime up?
Any remote start or antitheft stuff on it?
If a security light does it go out after key on bulb check?
MT
MT
Old 02-05-2008, 07:41 PM
it has 1/2 tank of gas the security light does go out when i turn the key it does have a remote start its been on there for four years dont know how to check for loss of fuel pressure or spark and dont know if the fuel pump is making noise or not i can smell gas after i try to start it its wierd
Old 02-06-2008, 09:07 AM
vando002 vando002 is offline
I am having the same exact problem! Was just coming on here to post about it. Happened to me yesterday right when this huge snow storm hit here in SE WI. I tried cranking it so much and let the key out that it chugged and chugged, sounded like it was an exhaust leak by the headers, then blue smoke came out from under the hood so I popped it open and the smoke was coming from under the washer fluid jug and I could smell gas too. Any suggestions would be awesome.
Old 02-06-2008, 09:13 AM
MT-2500's Avatar
AF - Advisor
You need a fuel pump pressure testing gauge and a spark tester.
MT
MT
Old 02-06-2008, 09:21 AM
MT-2500's Avatar
AF - Advisor
Best to start a New Thread on your problem and someone will help.
Saves hyjacking a post.
MT
MT
Old 02-08-2008, 07:39 AM
didn't mean to hijack, figured I had the same exact problem so I wouldn't add another post. Sorry.
Old 02-08-2008, 10:15 AM
MT-2500's Avatar
AF - Advisor
Another post is the name of the game.
Two different cars or problems on one post gets confusing.
There is very few exact problems.
Always start a New Thread for your problem.
Good Luck
MT
MT
Old 12-09-2008, 01:20 PM
Patrick_Z1 Patrick_Z1 is offline
I had the same problem with a 96 blazer that wouldnt start and I figured out when it sat for a month mice set up camp in the muffler and pluged it shut with straw, insulation & dog food. when I cut the muffler off it fired right up and ran great
Old 12-09-2008, 01:54 PM
brcidd's Avatar
brcidd brcidd is offline
If the engine tries to fire when you let off the starter- then check to see if you have 12v to the coil during both "Run" and "Crank" modes- I've seen bad ignition switches (on a '95 Blazer) that don't have igntion power (pink wire under dash) during "start" mode-but it was there during "run" mode - a simple jumper of 12v to that wire and it starts right up- needed a new ignition switch
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-09-2008, 03:51 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
This post is 10 months old...
