Old 02-05-2008, 08:16 AM
milk123 milk123 is offline
Bravada air suspension problem
Almost every morning for the last week, the rear suspension drops down all the way. It looks like the Bravada has a load of sand in it.
Where do they usually leak from and how expensive is it to fix?
The compressor is fine, when i go out in the morning, I just startup and the vehicle rises up to the usual height.
Anyone got any help?
Old 02-05-2008, 03:19 PM
wardak33 wardak33 is offline
Re: Bravada air suspension problem
what year is your bravada? if its a 2002-2004, then check and see if anything (like the hose) is connected to the compressor. and run the pump with the car on and listen for any leaks. it can be the nozzle where the compressor hose connects to.
2002 Oldsmobile Bravada AWD w/ SmartTrak
1999 Mitsubishi Galant 2.4L I4
Old 02-05-2008, 04:12 PM
It's a 2002. I was thinking that it could be around there because both sides go down. It's not totally failed because when I go out in the morning it inflates to the normal height and is good for the day while i'm using it. Are there seperate lines for each side or is it one line feeding both sides?
Old 02-06-2008, 04:47 PM
What the heck is going on here? Who moved this from the Olds Bravada forum? Why? What an insult!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-06-2008, 07:01 PM
old_master's Avatar
Advisor/Moderator
http://www.automotiveforums.com/vbul...d.php?t=692366
Old 02-08-2008, 08:40 PM
Do many Blazers have this type of suspension????
Old 02-08-2008, 10:39 PM
i know for a fact that the bravadas have them. trailblazers, and envoys, most likely do, especially the higher up models, but i'm not sure about the older blazers...
Old 02-09-2008, 07:13 AM
old_master's Avatar
Advisor/Moderator
It was available as an option on Blazer, Jimmy, and Bravada starting in 1994.
