Old 02-05-2008, 07:48 AM
mattd424 mattd424 is offline
brakes
just a quick ? does anyone know the size caliper socket i will need to take the calipers off a 01?
also on a side note i have a code for secondary air pump.what is this?im thinking its for emissions will it affect the way the car runs?
Old 02-05-2008, 05:20 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: brakes
I believe the caliper to bracket bolts are 15mm, but I havent messed with brakes in a while....I think the bracket to knuckle bolts are either 13 or 14mm.
Either way, its either 13,14, or 15, haha I know that doesnt narrow it down, but if you have even a cheap socket set, you should have all three.
As for the air pump, it is mainly an emissions device, its the little pump located basically behind the front bumper on the driver side, if you pull the driver headlight you can see it down there. If im not mistaken it takes the stored vapors from the gas tank and injects them into intake air stream. The car shouldnt really run any different, you might notice a slight decrease in gas mileage though.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 02-06-2008, 08:08 AM
Hoppy2 Hoppy2 is offline
Re: brakes
matt,
I beleive that you can just leave the pump alone and the engine will run ok. It only comes on at startup if the temperature is above freezing to say 40 or 50 degrees or so. It comes on only for about 1/2 a minute and once again a little later on just for a couple of seconds.
I would check with your province or state to see if the law requires the dealer to have an 8 year warranty on emissions devices on your car. You may get it replaced or fixed for free by the dealer if this is the case.
Hoppy
Old 02-06-2008, 10:23 AM
Re: brakes
it was 15 mm i got the brakes and tune up done.its in getting an alignment and tierod right now.car seems to run fine without the pump just that service engine light bugs me.i can clear the code but it comes back in a day or so.other than that i just haft to fix the throttle sticking.seems to be the tps from no pedal to lightly pushing it it sticks and takes force to open the throttle then moves freely but then it doesnt lways return eithier.
Old 02-06-2008, 10:29 AM
LittleHoov's Avatar
Re: brakes
You might take the TB off and give it a good cleaning, if you havent done it, it probably couldnt hurt anyway.
I had a similar issue off and on, sprayed the heck out of the spring assembly with WD-40 on the TB, but I think I cleaned it shortly after that, either way it went away.
Old 02-06-2008, 11:28 AM
dtownfb dtownfb is offline
Re: brakes
While you are cleaning the throttle body, you may as well clean the MAF sensor and check the air filter.
