Old 02-05-2008, 05:33 AM
dakkota65 dakkota65 is offline
96 jimmy
hi new here , having problem with driver,s power seat wont move/ checked fuse . even put used power seat got from friend it worked in his jimmy what can i do thanks
Old 02-05-2008, 09:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 jimmy
Welcome to AF.
Are you getting power and ground to the seat motor?
MT
MT
Old 02-05-2008, 05:07 PM
Re: 96 jimmy
hi no did not think about that .. what do i need to check?
Old 02-05-2008, 05:21 PM
MT-2500's Avatar
AF - Advisor
Re: 96 jimmy
Check switch for power on orange wire power feed wire from circuit breaker A in IP fuse box to power seat switch.
May have to have key on.
For ground black wire check for good ground wire on rear of right cylinder head.
The front to back motor reverses power and ground on light green and tan wires to move seat backwards or forward.
MT
Old 02-07-2008, 04:14 AM
Re: 96 jimmy
hi have,nt had a chance to check the seat.. fuel pump went on me ;had to get it towed to the shop . mechanic said pump is new and works got it back homeand let it sit overnight now it,s leaking ...gas guage is not working still what to do..... live in nj
Old 02-07-2008, 08:02 AM
MT-2500's Avatar
AF - Advisor
Re: 96 jimmy
If it is leaking gas take it back to the mechanic.
And also ask him to test/check the fuel gauge.
Where is it leaking?
Was the complete fuel pump module replaced?
Was the gas gauge working before the pump quit.?
How much fuel did you add after pump was replaced?
MT
MT
Old 02-07-2008, 04:07 PM
Re: 96 jimmy
well i took it back and he did not charge me . found out the hose leading from tank cracked,,the gas gauge wiring had rubbed up against the body causing it to short out ..works now perfect thanks for help
Old 02-07-2008, 05:40 PM
MT-2500's Avatar
AF - Advisor
Re: 96 jimmy
You are welcome and thanks for letting us know how it went.
If it is not right always take it back.
And give them a chance to fix it right.
Most good repair places stand behind ther work and want to know if anything is wrong with what they did and will work with you on getting it right.
Sounds like he done on taking care of the problem.
Good luck
MT
MT
