Old 02-05-2008, 04:54 AM
dale915 dale915 is offline
95 S10 4x4 4.3L Blows ECM Bat Fuse
I have a 95 S10 4x4 4.3, that will blow the ECM bat fuse only when the truck is in gear and I give it to much gas (goose it a little). When its out of gear I can goose the heck out of it and rev the engine to high rpm's and the fuse won't blow. I also had a repair shop run a diagnostic on it and it shows everything is fine. I've changed the fuel pump, wiring harness and ECM. Any thoughts about what it could be.
Old 02-05-2008, 06:14 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 S10 4x4 4.3L Blows ECM Bat Fuse
I think that fuse also powers abs brakes.
And the fuel pump oil pressure switch and fuel pump relay
Unplug them for a test.
MT
