Old 02-05-2008, 03:05 AM
dale915 dale915 is offline
95 S10 4x4 4.3L ECM Bat Fuse Blows
I have a 95 S10 4x4 4.3L, that will blow the ECM bat fuse only when the truck is in gear and I give it to much gas (goose it a little). When its out of gear I can goose the heck out of it and rev the engine to high rpm's and the fuse won't blow. I also had a repair shop run a diagnostic on it and it shows everything is fine. I've changed the fuel pump wiring harness and ECM. Any thoughts about what it could be.
Old 02-07-2008, 11:45 AM
j cAT j cAT is offline
Re: 95 S10 4x4 4.3L ECM Bat Fuse Blows
you will have to check wiring from fuse panel to ecm. i suspect wiring is chaffed where it crosses the engine from drivers side to passenger side front fender........
