Old 02-04-2008, 11:48 PM
pirata12's Avatar
pirata12 pirata12 is offline
Lesson Learnt....
Automotive Paint stripper is not a short cut. Unless you are part of a modelling crime family and want your kit (in this case the Eunos Roadster) to disappear.
I thought I'd be clever and speed things up by dunking the model in the stripper overnight.
Its vanished!!
Old 02-05-2008, 01:05 AM
wouter1981 wouter1981 is offline
Re: Lesson Learnt....
Next time, perhaps you can try to use one of those;
http://www.wagnerspraytech.com/porta...43297,747.html
Old 02-05-2008, 01:08 AM
pirata12's Avatar
Looks good! Thanks! I may consider that when I get a bigger place.
I'll probably do the brake fluid next time. I was just too lazy to do it.
Old 02-05-2008, 01:43 AM
I always use 95% Isopropanol. Every drugstore has it. And it removes almost any type of paint without damaging or softening the plastic. I've soaked the wheels of my caterham in it for over a year and there"s absolutly no damage.
Old 02-05-2008, 02:39 AM
lotus123's Avatar
lotus123 lotus123 is offline
Sounds like it doesn't work too well - sure it's not water? LOL
Graham
Old 02-05-2008, 05:38 AM
Graham
haha, no it's not water, but the paint is off ;-)
Old 02-05-2008, 08:30 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Brake Fluid & Castrol Super Clean work very good for stripping paint. However, brake fluid, if left in it long enough, will cause the plastic to go soft & distort. I lost a race car body to that once. But it had been in for probably 2 month.
Old 02-06-2008, 02:18 AM
janositamas's Avatar
janositamas janositamas is offline
Yes, brake fluid works very well but be careful with it: it makes the plastic soften after a longer time, I lost the roof of a Gallardo once, but worse happened to my Lexus LS600hL kit: front of the car broke into 1 cm pieces (but the paint came off ), so watch out for how long you dip your kit into brake fluid!
Old 02-08-2008, 10:42 AM
Didymus Didymus is offline
It will do the same to resin. And it will do the same to you if you dip your "kit" into it!
Ddms
