Old 02-04-2008, 09:38 PM
BGALLO BGALLO is offline
Test for power to fuel pump 2001 Astro??
Can anyone tell me how I can test for electricity to my fuel pump? I'm pretty sure the pump is faulty, but before shelling out big $$$ I wanted to make sure that it wasn't some electrical problem. I dropped the tank down and disconnected the large 7 lead connector that powers everything - ground is good. When I turn the key I can hear the fuel pump relay under the hood click over. I would like to know what leads I should check in the connector to make sure power is sending to the pump. Any help would be great.
Old 02-05-2008, 06:22 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Test for power to fuel pump 2001 Astro??
You already know the pump is seeing voltage- you stated you can hear it run... a better way is to look at amp draw-- put your VOM in series with the fuel pump primer lead and see how many amps are being pulled-- also good to know- and the primary decision maker is the fuel pressure-- measure with a gauge the test port on the fuel rail-- if pressure is low- you either have a leak or a worn out fuel pump
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 02-05-2008, 09:05 PM
Blue Bowtie's Avatar
Registered Offender
It's very common to have the electrical connectors in the pump unit (not the pump itself) begin to fail and cause a reduced voltage at the pump motor. This is a very common problem, and is frequently overlooked, or misdiagnosed as a failing pump. This is also one reason that the pump alone is not usually offered as a replacement part, since replacing to pump does not solve this problem.
Old 02-06-2008, 04:09 PM
old_master's Avatar
Advisor/Moderator
Hearing the relay click is the first step. At the fuel pump module connector, the 2 black wires must show less than 5 ohms resistance to ground. The grey wire should show battery voltage for 2 to 3 seconds after the ignition is turned to the RUN position, and continously when the ignition is in the START position.
Old 02-19-2008, 12:07 PM
Thanks guys for the tips. Old Master, the ohms checked out so I replaced the pump.
