Old 02-04-2008, 05:52 PM
Gmcred Gmcred is offline
97 Jimmy speed problem???
Today on my way to work my 97 Jimmy was driving slow...it seemed like it had a hard time getting into gear and moving at normal speed. I have no idea what the problem could be, but it almost felt like it was in 4wd low, but I checked everything and that wasn't the problem. (No, my parking break was not on either.) Any help would be much appreciated, thanks!!
Old 02-04-2008, 08:41 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 97 Jimmy speed problem???
Did the Check Engine light come on?
Is it driving ok now?
Have you had any work done on it recently?
Old 02-04-2008, 08:59 PM
Yes the check engine light is on.
I have not had it worked on recently.
The problem is still persisting.
...I was suggested that I probably need my transmission fluid replaced so I'm going to do that and see what happens. Thanks for the response tho.
Old 02-04-2008, 09:52 PM
AF - Advisor
Have the auto parts store do a free computer scan...most chain type stores do it free.You might shift each gear manually in case there's a shift solenoid malfunction.
