Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee > Classifieds
Old 02-04-2008, 06:50 PM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
89 CRX Body kit 19 inch Wheels F/S
89 CRX Custom with Body kit and 19" wheels. Runs great. Two new tires the others are 75% or better. Brakes are good has alpine cd player 12" pioneer subs, JL highs, 600 watt amp and mtx high amp. 2.25 exhaust with performance muffler(not in picture) Interior is complete which is hard to find seats have no rips. come take a look $1800 and will throw in an extra set of wheels 17" Lexani iris with excellent tread good condition. Clearwater/ Tampa Area pm if interested
Old 02-08-2008, 12:57 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: 89 CRX Body kit 19 inch Wheels F/S
Thought you sold those Lexani's?
Thought this was your next project?
WTH happened?
Old 02-08-2008, 01:46 PM
sofast's Avatar
WTH happened?
I thought I sold the wheels but the dumb sucker was a dead beat so I relisted and sold them today for $450.
As for the car I had it sold 2day but on the way to work I lost compression in cylinder 2. running 15lbs. so this car and i were meant to be. i will keep it forever because it likes me I guess. You know of anyone with a sohc motor?
Old 02-08-2008, 07:29 PM
Not around you, but they aren't that hard to find.. use the B2 block that you have, toss a Z6 or Y8 head on it, and don't tell Frodo if you pick up the whole motor... he'll hate you.
dude has encountered 3 deadbeats looking for a motor... if you get one first try, he'll probably hate you for life... or offer to buy it off you.
The B2 head is the same thing as the A6 head, but if you wanna put Si cam in it, you'll need either a adjustable cam gear, or a Crank pulley (timing) from the Si as well... which means alot of work, the crank snouts are diff sizes.
quick swaps, you could either do the ZC swap, what i'm doing, or mini-me it, or do a Vtec swap and run the stock PM6 ECU w/ a RPM activator switch for the Vtec... don't complain when you figure out that you're running way lean in Vtec tho. (To do this right also requires a second fuel pressure regulator and an electronic valve... so that you get enough fuel in Vtec, you set the second pressure regulator higher than the first, and the electronic valve to change the line so the fuel coming from the first pressure regulator will run into the second one and get stopped, allowing more pressure in the rail.) (Or you can get an electronic two-step FPR, and control it from the RPM switch as well)
You could also just go OBD-1 for Vtec, and stop whining about emissions laws (not that you were, but it pisses me off when ppl do.)
Old 02-08-2008, 07:31 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Aye, I will..especially now that I realize that the y7 I sold a couple months ago is the same short block as the y8.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-08-2008, 07:37 PM
\LMAO\... that's all I have to say... do some \RESEARCH\ :P
