Old 02-04-2008, 10:41 AM
Hinesly@grandecom. Hinesly@grandecom. is offline
Keyless Entry programming for 05 Grand Am
I ordered 2 keyless entry remotes from ebay. Is it possible to program them w/out taking the car to dealership?
Old 02-04-2008, 06:17 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Keyless Entry programming for 05 Grand Am
Welcome to AF.
that would be a big NO !!
It only takes 5 minutes tops.
1999 Grand Am SS 3.4 OHV
Old 02-04-2008, 07:17 PM
coolpapaj coolpapaj is offline
Do you have the instructions? Would you mind posting them?
Thanks.
Old 02-04-2008, 08:55 PM
Transmitter Programming
Important
All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body, go to Remote Function Actuation.
Select Special Functions.
Select Program Key Fobs.
Select the number of key fobs to be programmed.
Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds. The power locks should cycle to confirm programming of the first fob is complete.
If you are programming more than one transmitter, repeat the previous step to program up to 4 transmitters.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation
thier you go.
Old 02-06-2008, 07:32 PM
Thank you!
