Go Back   Automotive Forums Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 02-04-2008, 10:25 AM
Rodrigo072788 Rodrigo072788 is offline
strech metal
I was wondering is you can shrink or strech metal in a body line??????
Any thoughts?????
Old 02-08-2008, 09:25 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: strech metal
Before i answer this, id like a bit more clarification... what type of body line are you talkin about? and what is the purpose of shrinking or stretching? Are you trying to remove the body line as a way of smoothing out the body panel?
Old 02-08-2008, 09:06 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Re: strech metal
Are you trying to smooth out body lines? OK shave moldings? Are you trying to gain a slight fender flare? I have seen small fender flares/IE "pulling a fender" done, but if you are trying to shave anything, that's not the way to do it. Post up what you are wanting to do.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 02-09-2008, 04:53 PM
CarBeater CarBeater is offline
Re: strech metal
Body lines are pressed into the steel from the manufacture to add shapes, features, and to provide additional strength to the panel. The stamped body lines create tention on the steel, which work hardens the metal. Therefore, the body lines are the strongest points of the panel. It takes more impact to cause damage on body lines;however, once damaged, it will make the repair more difficult as well.
With that said, metal on a body lines or any other part of the panel may be streched during a collision. The streched metal must be shrunk to its original (pre-accidental) state. If not, the metal will be weaker than it should.
