Old 02-04-2008, 01:52 AM
bombcitydavid bombcitydavid is offline
f20c1 swap
my b20 in my 90 hb is not fast enough i was thinking about a f20c1 if it is the same block as an h22 could i do it or is the extra hp not worth it .i know the f20c1 was rwd but with a h trans or a b or d trans with adpt plate.and h motor mounts.or should i just get a h22a
Old 02-04-2008, 02:41 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: f20c1 swap
just get the h22... the f20 will be 3 times more expensive and 10x the headache.. as if the h isnt already. Better yet. Get a b16/b18c1, or c5 head and make a b20/vtec and watch your b20 come to life. If you build it a little more youll have just as much power as that h22, youll be alot lighter and faster, and still handle just as well.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 02-04-2008, 01:31 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: f20c1 swap
yeah i was gonna say b20/vtec..youre most of the way there anyways just get a new head..
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 02-04-2008, 02:42 PM
Re: f20c1 swap
thanks for your reply. but if you put b16 head on don't you have to put new pistons and rods.plus all the work you have to do to the used head.would it not be cheaper to go h22 and still get more hp
Old 02-04-2008, 04:53 PM
FrodoGT's Avatar
Re: f20c1 swap
Nope, you dont HAVE to do any of that..youll make more power if you go for high compression pistons and do port and polish and cams to the head. But hell make a good amount of power just with the conversion. An h series swap is a pain in the ass that requires the finesse of a shoehorn. Youll be cutting parts of your car apart and its by no means cheap. You can get a head for 250-300 in some cases and then an ls/vtec conversion kit will finish it if thats as far as you want to go.
Current project:
Rio Red 91 hatch.
