Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-27-2008, 02:28 PM
buddylov buddylov is offline
Send a message via AIM to buddylov Send a message via MSN to buddylov
1995 pontiac bonniville 3.8
hello everyone, have a lettle problem with my bonni. here is all i have done,,
the engine truns over but not getting any gas, however i have check the fuel perssure regulator it's gaving 38 psi. also check for ground evrything looks goodinside and out. however i put starter fluid in the engine and it will run untill the fluid brun out. my injector are not opening-up. i have check all the fues and they look good. lease help me on this. thank you
[email protected]
Old 02-03-2008, 02:05 PM
hello have a big problem with my bonni. it will trun over but will not run. i have change the cam senssor, the crackshaft senssor but a new hamanic balncer, new wire and plugs and it will not run. the only wa it rum is f i put starter fuild then it die... i hve notice that when i discounnet the battery for a long time the redio won't lock up like it should. maybe a short in the car. please help me. this is my wife only car.
[email protected]
Old 02-03-2008, 06:59 PM
Mickey#1 Mickey#1 is offline
Re: 93 bonneville no start
Check all the fuses. Don't miss the ones under the dash on the passenger side. Also remove the rubber boots from the battery cables and clean the corrosion off the cable ends. If it still won't start:
1- Check for spark at each of the three front cylinders.
2- Check fuel pressure at the fuel rail.
3- Check for fuel injector pulse.
