Old 02-03-2008, 07:37 PM
ZMM93 ZMM93 is offline
95 quad 4 spark plug removal?
ok so i have the target in my sites and if your familiar with the V6 Quad 4 not sure if its a 2.3 or 2.4 but they are in like a creves and im afraid to take a pliar to them and what not so give me tips on how to get to them if i remove something or what ever, for those who dont understand i included a picture just click on it to enlarge it, i know u guys can hep me.
they are hiden behind/under the bar under the top of the quad 4.
Old 02-04-2008, 12:13 AM
kallenbach_05 kallenbach_05 is offline
Re: 95 quad 4 spark plug removal?
remove the 4 bolts on top of the cover and they are under there.
Old 02-04-2008, 04:30 PM
98xploder 98xploder is offline
quad4 is a 4 cylinder.. not a v6. dont be surprised if you only find 4 plugs under the IDI covor. at any rate, if they dont come out on the socket, (best to use spark plug socket with rubber insert to hold the plug) then just pull them out with pliers. you dont have to mega grip on them and crack the plugs, just be gentle, take your time, and youll be fine.
I never run stock...
Old 02-04-2008, 05:51 PM
wow so its 4 valves per cylinder, im about to go in in a bit and put this newly gained knowledge to work, ill share my experiences upon return
Old 02-04-2008, 06:57 PM
do i just pull them out, twist them out or what i couldnt tell it was so narrow i flt like they arent supposed to just be pulled out. what do i do
Old 02-04-2008, 07:04 PM
the plugs? get your ratchet down in there with a spark plug socket and extension, unscrew em, then they should come right out.
Old 02-04-2008, 07:07 PM
dam i dont have a sparkplug socket is there an equivilent?
Old 02-04-2008, 07:20 PM
should be 5/8 or 11/16 deepwell socket.
Old 02-04-2008, 07:30 PM
awsome ill try that tommorrow
Old 02-04-2008, 07:40 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Get a spark plug socket. If you use a 5/8 deep socket you run the risk of breaking the plug, plus its a real b*tch to get the plug out of the hole after you loosen it.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 02-04-2008, 07:42 PM
true that. it can be done without, but i recommend spending the 3 or 4 bux on the right socket.
