1978 Caprice fuse help, please.
My husband is restoring his mother's 78 Caprice. Everything works except the door locks, horn, and cigarette lighter. He has checked all the fuses he can find and swares there must be another fuse box someplace. Are there two fuse boxes and if so where are they. Also, is there a place I can get a picture of the fuse box and what each fuse is for? He can't find the owner's manual right now. Thank you.
Re: 1978 Caprice fuse help, please.
those are three different systems
only one fuse panel in these cars the horn uses a relay it is rectangle and three spade plugs into the panel like the turn signal and hazard flashers do the locks have a relay and also a circuit breaker are two circuit breakers in the fuse panel, both metal and a little bit bigger than blade style fuses can be a bad lock door switch will have to us ea process of elimination to figure out what is wrong with each system cigar lighter commonly fail because they are simply old and junk make sure it is hot in the center and ground around the inside of the socket) all the metal) with a test light make sure the horn wire at the cap is getting ground from the horn cam that runs around the steering column under the steering wheel you will ahve to understand how these systems work and wire colors for each to figure out why they are no longer working usually it is a component that has failed almost always unless visual wiring damage is seen or found suspect switches and components and harness plugs first the horn wires are dark green they will be ground when the horn button is depressed the cigar lighter is black and orange normally orange hot all the time make sure grounds are good on the driver side under the end of the dash at the door pillar frame there are black ground wires and a blade connector screwed to the car metal that ground wires are plugged onto make sure they are all good if the circuits show hot in the fuse sockets, on both sides of the fuse if not hot on one side with fuse installed, or no hot on either side fus einstalled or not then you have a feed problem or key needs to be on to run that circuit no key needed for locks and cig lighter or horn even so.. if you are missing hot or ground in any of the circuits then check relays and breakers and switches and so on
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
