Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-03-2008, 06:06 PM
userpete1037 userpete1037 is offline
1989 Toyota Camry (Fuel Pump Location)
Can you get to the fuel pump by taking the rear seat out or do I have to lower the tank?
Old 02-03-2008, 08:19 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1989 Toyota Camry (Fuel Pump Location)
You have to lower the tank (after you disconnect the negative battery terminal)
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 02-04-2008, 12:14 AM
Thanks. I appreciate the response.
Old 02-04-2008, 10:22 AM
Brian R.'s Avatar
Resident Chemist
Download a FSM for your car using the link in the sticky thread at the top of this forum.
Old 03-16-2008, 10:52 AM
toyotabill toyotabill is offline
Unhappy Re: 1989 Toyota Camry (Fuel Pump Location)
Hey I have an 86 camry it starts for 5 seconds then dies. No matter what
I replaced the fuel filter, relays, tune up. any thought.
toyotabill
Old 03-16-2008, 11:11 AM
Brian R.'s Avatar
Resident Chemist
toyotabill
Bad fuel pressure regulator or bad fuel pump, obstruction in the fuel line.
Old 03-16-2008, 09:32 PM
JOET/CAMRY JOET/CAMRY is offline
toyotabill
A similar issue happened to me when I owned a 1985 Camry. the car would start up and idle but if I put it in gear or if I would try to rev the engine the car engine would die. it would start right up though.
after replacing many, many,many parts on it I was in the process of replacing the fuel pump and discovered the electronic fuel pump had a 99% clogged fuel strainer/filter on it.
once I replaced the filter/strainer the problem solved. I had to drop the gas tank to get at the electronic fuel pump. no access to it by removing the back seat. Hopefully you won't have to drop the gas tank. What a PITA job that was.
Good luck with your car.
Regards,
JOET/CAMRY
Old 11-15-2016, 03:00 PM
maryannbritz maryannbritz is offline
I had a simular problem with my 89 camry , wud run for a few seconds then stop. it wasnt fuel but air. on my camry there is a plug that attaches to the air cleaner. this plug is retangle shaped and it plugs in to the hose to the air cleaner. it had a dry circuit and bent pin. once the pin was straightened and plug packed with a bit of grease it never did it again. hope this helps
The Following User Says Thank You to maryannbritz For This Useful Post:
Brian R. (11-15-2016)
