Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-03-2008, 05:06 PM
RedWind RedWind is offline
1991 Camaro problem starting
I just bought this car and it ran perfectly for about a day then it starting cutting out, and then it got worse and when I would push on the gas more then just a tiny bit it would start to cut out until I would let off, now it wont even turn over, I checked the spark and it good I changed the filter and thats good, I check the pressure and that is also good, now I am stumped it went everything seems to be fine but it wont turn over.
Old 02-04-2008, 01:28 PM
Re: 1991 Camaro problem starting
sorry for double post
alright now it is starting but when I go to rev it up it chokes out you will feel it accelerate and then the acceleration will cut out and then the engine will cut out.
Old 02-05-2008, 01:18 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
miles, engine size & fule delivery system please.
What is the "ok" fuel pressure reading?
Old 02-05-2008, 01:39 PM
its a V6 3.1, fuel injected, it has 150,000 on it which is low for that old of a car
Old 02-05-2008, 04:07 PM
wrightz28's Avatar
So what is the fuel pressure at?
Old 02-06-2008, 09:03 PM
it idels around 40 PSI but as soon a I give it gas it cuts out
Old 02-06-2008, 09:24 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
bad fuel pump is my guess
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 02-07-2008, 08:28 AM
wrightz28's Avatar
Ehhh,
For the giggles of it, check the pressure regulator line for gas.
Old 02-09-2008, 08:02 PM
Update:
I did a tune up, and filled my tank and added water remover and I got it to run now, but when I rev it up and around 2500 it starts missing and lights pulse with the miss.
Old 03-14-2008, 01:03 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
I dont know if you solved your problem but if u havent, I would check the EGR system....it kind of sounds like you're getting a signal for the EGR to turn on earlier than u should....Try disconnecting the wires going to the digital EGR valve..Im just as stummped as you are...let us know if u solved the problem...It also sounds like you're not getting enough air...I would check for a serious vacuum leak somewhere...Take out the IAC motor and reset the pintle....another thing...I would check for a code in the computer even though the light is not on...there might be something there believe it or not...Im also suspecting that the ECM might be going...hope u fix it!!
