Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-03-2008, 04:12 PM
bluebird1955 bluebird1955 is offline
Grand Cherokee Radio cassette unit
Hi all, I am in England and would like to update the radio in my 1998 Grand Cherokee Orvis. Does anyone know if it is a standard 2 DIN radio, and what kind of wiring problems could I expect?
Many thanks.
Old 02-03-2008, 04:19 PM
msdz msdz is offline
Re: Grand Cherokee Radio cassette unit
You can buy adapter kits to place just about any type of radio you want in the Jeep a long with wiring adapters. The wiring adapters just plug into the factory radios speaker and power harness that way you should not need to cut any wires on the Jeep. All the wire connections that need splicing and taping/soldiering or however you decide to mate the joining wires are done outside the Jeep between the radio you have and the wire adapter.
Old 02-03-2008, 05:33 PM
Hi,
Do you know if it is a double DIN radio? Is that a familiar thing is US?
Old 02-05-2008, 11:46 AM
JeepForever JeepForever is offline
Most of the Jeeps I've seen have a single DIN (single-height radio bay). You should be able to tell just by looking at the size (height) of the radio. If it's single-height (about the height of the air vents or the A/C control knobs) it's a single-DIN. If it's about twice as high (usually these have a video display screen) then it's likely a double-DIN. Since you have a cassette player (older model) I'd guess it's a single-DIN. If you want to be sure, measure the height of the radio (to the inner edges of the dash board trim) and compare that to what you see in the store. If it's close (within one or two centimeters) then it will fit fine with a universal trim kit. If the new radio is nearly twice as large (2-DIN), it won't fit in the bay.
In my '94 Jeep GC I purchased a stock radio from an audio store and it fit right in (needed to get the adaptor cable that msdz referred to).
Old 02-05-2008, 02:13 PM
reekor reekor is offline
Yes its a double DIN radio.
Originally Posted by bluebird1955
Hi,
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 02-05-2008, 02:44 PM
Thanks for your help! I am having difficulty getting an conversion lead that will fit the amplified model, do you know of any supplier?
Old 02-05-2008, 08:21 PM
I havent seen any, the one jeep we have came with an aftermarket radio whoever did the install cut the factory harnesses at the amplifier and joined them together.
