Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 02-03-2008, 03:13 PM
Luke Home's Avatar
Luke Home Luke Home is offline
Rack & Pinion ... Seal Replacement??
Hello,
Does anybody know how to get the passenger side inner seal replaced on the rack & pinion? I would like to know how to get the end off so I can get at the seal beyond it to replace it because it leaks. Please see the picture below:
Picture Link:
Thanks ....
1998 Bonneville SE 156,000+, Miles, Running Good So Far
1999 Camry LXE 105,000 3.0 V6 (1MZ-FE Engine), A541E Trans.
1997 EAGLE TALON ESI 2.0L L4 SFI DOHC 16V (Project Car - 140K)
Old 02-03-2008, 05:21 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Re: Rack & Pinion ... Seal Replacement??
I think those are hydrolic pressed.
2004 Mazda 6i
1997 Tahoe
Old 02-04-2008, 06:11 AM
Luke Home's Avatar
Ok ..... any experience in getting the end removed to replace the seal beyond it??
Old 02-05-2008, 02:53 AM
MazdaX's Avatar
Well if they are hydrolic pressed then you need a hydrolic press/pull to pop them free and get into the seals and bearings inside. I would recommend taking it to either someone who works with axles or the dealership for the seal replacement.
Good luck on the repairs.
2004 Mazda 6i
1997 Tahoe
Old 02-05-2008, 06:50 AM
Luke Home's Avatar
... I would recommend taking it to either someone who works with axles or the dealership for the seal replacement. ...
Thanks for the reply ... I do not mean any offense here... But
I think NOT! The main reason for forums is to educate and share experience of Hands-On repairs. Certainly there maybe times when one has to go to a specialized service for repairs, but I guess the obvious would be … then we won’t need any of these forums.
For those who do not want to get a rebuilt or new rack & pinion and are willing to learn, and yes make the mistakes to gain experience, here is some info from another forum:
Rack & Pinion Seal Kits can be purchased from www.rockauto.com
And a link to a good start to rebuilding your own rack & pinion is:
Here
Hope this helps somebody else ...
Old 02-05-2008, 08:02 AM
ned032002's Avatar
ned032002 ned032002 is offline
That seems like one hell of a project. I would seriously recommend going to some one to have that done.
Old 02-05-2008, 10:17 AM
Luke Home's Avatar
Originally Posted by ned032002
That seems like one hell of a project. ...
On a scale of "one hell of a project" (10) and "going to someone" (1) ...
where does pulling a motor/trans, rebuilding the motor completely, and chancing out the Over-Drive Disc on trans fall in??????
I think this project would be elementary given a few good forums and a few people who have been through it.
I guess I think different and that is my 2
Old 02-05-2008, 10:18 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I would also recommend have it done by someone who knows about this stuff.
The problem is that no one on here has probably ever attempted this and thats why no one is helping you. If you really want to do it yourself you would be better off searching the internet and try to find out how to change the seal. You should be able to find enough info that will help you out some.
http://www.dsmtuners.com/forums/arti...ring-rack.html
I also saw where someone gave you this link on dsmtalk, this is all the info you need.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-05-2008, 10:24 AM
Luke Home's Avatar
Originally Posted by SilvrEclipse
...If you really want to do it yourself you would be better off searching the internet and try to find out how to change the seal. You should be able to find enough info that will help you out some.
Thank you ... this is very good advice ... and I will heed to it.
I will post back if anybody cares to hear about the out come.
Luke
Old 02-05-2008, 10:30 AM
Holset powered 420a
Why dont you give us a write up for it. That way we wont have this problem in the future.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-05-2008, 10:31 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
I would like to see how this turns out and as always I encourage people to do things on their own. You do need the right tool for the right job, which is where the shop usually comes in, but it's entirely on you. Good luck and let us know how everything goes.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-05-2008, 06:11 PM
MazdaX's Avatar
Heh..well live and let live and let learn I say.
Drink of the month btw is White Russian =P
2004 Mazda 6i
1997 Tahoe
Old 02-25-2008, 09:16 PM
Luke Home's Avatar
Well, finally got the rack and pinion rebuild this last weekend. And really, there is no need to add much else to the "How-To" link above. The only problems I had was getting the inner seal out. That baby is over 11" down in the tube and with no lip to knock it out from the other end with a long shaft. I ended up using a long screwdriver and able to bend the side wall over to create a lip that I was able to get the knock-out shaft on from the other end. The only other thing was the 5 nylon wipers .... they took a bit to get them on without breaking... but it was possible. Still need to get it installed for the final test. But of coarse the motor needs to back in too before actual rack & pinion testing can take place. I would advise any body willing to rebuild a motor to certainly rebuild there rack & pinion if it needs it.
My
