Old 02-03-2008, 12:16 PM
steketet steketet is offline
Shift Solenoid
Anyone know where the shift solenoids are located on a 98 Chevy Blazer, 4.3L V6 4wd? I need to change the 2/3 shift solenoid and not sure if I have to remove the pan or if it is mounted on the outside. I have contacted autozone and they say it is not in side the pan.
Old 02-03-2008, 01:58 PM
old_master's Avatar
Advisor/Moderator
Re: Shift Solenoid
Autozone if fine as long as you don't ask them any questions. The transmission oil pan must be removed to access the shift solenoids.
Old 02-03-2008, 06:45 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Shift Solenoid
did you get a po758 code? i just had this happen to my truck. shift solenoid B is the one you will probably have to replace, about $20 for another one. both shift solenoids are at the rear of the valve body so the pan needs to be dropped to replace it. you will also need supplies like 6 quarts of trans fluid, filter, and pan gasket. took me about 1hr 1/2 - 2hrs to replace the solenoid.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
