| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
wont start!!!
hey guys its still me here, i decided that i shoul consolidate the last thread about charging so that this would be more efficient, idk how to delete the old one so if a moder. can thats cool.....
my 95 rs, wont turn all the way over. it just hesitates....it shut off in the middle of driving, after makin a clicking noise, which silenced when i engaged the clutch... i tested the battery starter and alternator...all is good...what more could i check, maybe some connections, or cables??? which ones, where are they located??... im starting to think that its maybe a mechanical problem??? i was on minimum oil and a small radiator leak..., i fixed both. when i engage the clutch , then start the car it will move about 6inches or so , but still wont turn all the way... help fellas and thanks for helping me so much all ready
civics are for suckas 95' eclipse gst stock turbo new C.A.I. programmed ecu 2.0 DOHC manual greddy bov im workin on it. slowly but showly |
Re: wont start!!!
Make sure your battery is charged good. Clean the battery terminals, the cables going to the starter, and any grounds you can find. If the car still wont turn over, then maybe your starter is dead.
Also how do you know your battery is good. Put a volt meter on the battery and note the voltage, have someone turn the key cranking the car and see what the voltage goes to.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: wont start!!!
I think shold add a link for the other thread man.
'98 Contuor SE, 2.5 V6 Auto Silver '08 Altima 2.5S, Auto Super Black |
Re: wont start!!!
thanks i'll try some of those things tomorrow, i got the battery alt, and starter check at autozone throughly. is ther any mechanical things i can check for, maybe its sparks or something!!! how do i check those!!??
Re: wont start!!!
http://www.automotiveforums.com/vbul...d.php?t=885209
If the battery test fine then maybe its the starter. Or you may want to try and turn the motor by hand to make sure its not locked up. I highly doubt it is but that would eliminate the possibility. Put a socket on the crank bolt and turn clockwise.
Re: wont start!!!
Re: wont start!!!
Maybe if it jumped timing and the valves are hitting pistons
Re: wont start!!!
where can i find the crank bolt....i think it may be the spark plugs??? how do i check them???
Re: wont start!!!
